2000 Chrysler 300 Brake light stay on after car is turned o
2000 CHRYSLER 300
240,000 MILES • 6 CYL • FWD • AUTOMATIC
TREALONE
I have a serious problem. My car does not have illuminated brake lights. I have replaced the brake light switch, I replaced the fuses, I replaced all of the bulbs. The lights even stay on when the car is turned off. The problem was resolved when i first addressed this issue on here, but now it's More
I have a serious problem. My car does not have illuminated brake lights. I have replaced the brake light switch, I replaced the fuses, I replaced all of the bulbs. The lights even stay on when the car is turned off. The problem was resolved when i first addressed this issue on here, but now it's back, and now my brakes lights do not work. What could the problem possibly be?
Feb 26, 2010 at 8:29 AM
Did you adjust the brake switch properly?
Feb 26, 2010 at 8:41 AM
TREALONE
Thanks for the reply. Is there a certain way the brake light switch has to be positioned? Should the stem coming out of the switch be long or short upon installation?
Feb 26, 2010 at 8:47 AM
The stem/plunger should not be depressed it should lightly be touching the brake pedal arm-do a trial and error-get a helper to observe the light
Feb 26, 2010 at 8:52 AM
TREALONE
Okay. I have a brand new OEM brake light switch that I bought today, and the stem was not fully extended, should it protrude more then half an inch or is this okay. The reason i ask this is because my brake light switch doesn't stick out much.
Feb 26, 2010 at 8:58 AM
TREALONE
Thanks when i adjusted the brake switch everything was just fine, thanks again.
Sincerely
Treal'one
Feb 26, 2010 at 10:41 AM
