1998 Chevy Venture Sputters and Backfires
KELC28
Hello...I have a 1998 chev venture 3.4L with about 225,000km
I just changed the fly wheel on it, and put the motor back in, and hooked everything up.When I started it, it idles reasonable but when I give it gas it sputters and every once in a while it has small backfires....they arent loud more like a putt........putt....and the engine doesnt seem to have much power when I got to take off....Everything worked fine on it before the fly wheel went, so I don't know whats wrong..I keep checking to see if i forgot to hook up something but theres nothing ? Is there something I did wrong or what could it be?
Thanks in advance for your time
Trevor
May 9, 2007 at 5:30 AM
ROCKWOOD84
  • 103 POSTS
are you sure you got the fuel lines hooked up right. my fuel pump went out the same way it started to sputter the back fire put a gauge in where the fuel filter is and see what the pump pressure is supposed to be 40 lbs. pump is going to run about$320.00 and you have to drop the tank.you will need to get a set of gm quick release fitting tools about $15.00 to take the fittings loose. good luck
Jul 14, 2007 at 8:48 AM
Suggested Repair
After the engine reinstall, verify the fuel lines are connected correctly. Test fuel pressure at the fuel filter; it should be about 40 psi. If pressure is low, the fuel pump may be failing and may need replacement, which requires dropping the tank and GM quick-release fitting tools.
Conversation Summary
A 1998 Chevrolet Venture 3.4L idled reasonably after a flywheel replacement and engine reinstall, but sputtered, made small backfires, and lacked power under throttle. It had run fine before the flywheel failed. The expert suggested checking fuel-line connections and measuring fuel-pump pressure at the filter, expecting about 40 psi, and noted a weak pump as a possible cause.
