Air conditioning
PATSYDR2
The air conditoning will turn on but only blow air out of the rear vents of our 2004 Chevy Venture. I have checked all fuses pertaining to the AC but no luck, any advise? :cry:
I am hoping for any advise before I can even afford to take my vehicle into a repair shop.
Jul 21, 2007 at 10:21 AM
ROCKWOOD84
  • 103 POSTS
did you check both fuse boxes one should be passengerside end of dash.you should have the blower fuse for front and back they should be 25 amp the diagram for the fuses is on the lid or cover. also there is a box under the hood on my '99 silhouette there is not any for the blower in this box my blower fuses are in one on the end of dash. if the fuse is good then it could be the blower motor
Jul 22, 2007 at 7:10 AM
