2004 Chevy Venture AC Only Rear Vents
PATSYDR2
The air conditoning will turn on but only blow air out of the rear vents of our 2004 Chevy Venture. I have checked all fuses pertaining to the AC but no luck, any advise? :cry:
I am hoping for any advise before I can even afford to take my vehicle into a repair shop.
Jul 21, 2007 at 10:21 AM
ROCKWOOD84
  • 103 POSTS
did you check both fuse boxes one should be passengerside end of dash.you should have the blower fuse for front and back they should be 25 amp the diagram for the fuses is on the lid or cover. also there is a box under the hood on my '99 silhouette there is not any for the blower in this box my blower fuses are in one on the end of dash. if the fuse is good then it could be the blower motor
Jul 22, 2007 at 7:10 AM
Suggested Repair
Check both fuse boxes, especially the passenger-side dash-end box, for the front and rear blower fuses (typically 25 amp). If those fuses are good, the front blower motor may be faulty.
Conversation Summary
The owner of a 2004 Chevy Venture says the air conditioning runs but air only comes from the rear vents after checking the A/C fuses. The expert advises checking both fuse boxes, particularly the passenger-side dash-end box for the 25-amp front and rear blower fuses, and says a good fuse points toward a possible blower motor fault.
