2002 Chevy Venture AC Blows Warm
LHEAVNER
I have a 2002 Chevy Venture minivan 3.4L with 55,000 miles. The air conditioner is blowing warm air. I checked the compresser and the clutch is running. The system was low in refrigerant so I charged it up to 37 psi. The chart on the refrigerant can said the normal pressure was from 25-45 psi. The air conditioner worked great for about a day but now it is blowing warm air again. I checked the pressure and it is down to 30 psi. There is obviously a leak. The refrigerant I added says is has stop leak in it but this did not seem to stop the leak. Should I charge the system again and if I do will it just leak out again? Please help! Thank you.
Mar 13, 2007 at 3:44 PM
ROCKWOOD84
  • 103 POSTS
do you have oil on the compressor clutch pully or the serpentine belt? if so then there is a seal behind the compressor pully that is leaking .the kit is $45.00 and clutch tool $30.00 and you have to take cooling fans out to get a/c compressor out. there is a c clip that is in front of the seal remove it split the compressor push the seal out remove green outside seal 'o' ring
that is on the outer of seal[ can't see it till you get seal out] reverse order to reassemble. mine was leaking and only way i found it was the compressor oil
Jul 14, 2007 at 10:14 AM
Suggested Repair
Check the compressor clutch pulley and serpentine belt for oil. If oil is present, the shaft seal behind the pulley is leaking and should be replaced rather than simply recharging the system. The seal kit and a clutch tool are needed, and the cooling fans must be removed to access the compressor.
Conversation Summary
The owner of a 2002 Chevrolet Venture says the AC blows warm air even though the compressor clutch engages. A refrigerant recharge restored cooling for about a day, then pressure dropped again, indicating a leak that stop-leak did not fix. The expert says oil on the compressor pulley or belt points to a leaking compressor shaft seal and outlines replacing that seal.
