Transmission problem 6 cyl Two Wheel Drive Automatic 123000 miles
We recently had the battery changed...3 days ago and everything was fine. This morning when we got into the van, we started it, put it in reverse and when we went to put it back into park to run into the house to get something we needed, we weren't able to put it into park and the engine shut off. Now when we try to turn it on, it will not start and the gear shift will move but won't shift into any other gear. The light stays lit on the R and the reverse tail lights won't turn off either. Please advise to what you think the problem is and is there anything we can try to fix it.
Thanks!
Thanks!
Jul 10, 2010 at 8:49 AM
