2000 Chevy Express Backfires When Hot
DGHAHN
  • 6 POSTS
My 2000 chevy express 1500 with 110,000 miles, started hesitating on acceleration 4 days ago. In the past 4 days it steadily got worse until now when it won't go above 30mph. It runs fine at idle, and will run normal when cold. But after 5 minutes of running it will backfire and sputter if I press the pedal more than a fraction of an inch.
The fuel pump was replaced about 4 months ago, and the transmission was replaced about 3 weeks ago. I have replaced the spark plugs, distributor cap and rotor.
Jul 13, 2007 at 2:10 AM
2CARPRO JACK
  • 11,533 POSTS
First verify fuel pressure just to be sure.Could be a few different things. Is or has the check engine light been on? Try loosening the exhaust flanges and driving it, noisy but will eliminate the possibility of plugged exhaust. Have the PCM scanned to see if any trouble codes have been stored.
Jul 13, 2007 at 3:23 AM
DGHAHN
  • 6 POSTS
The check engine light is not on, but I will check it with a code reader.
I also noticed that there is a high pitched whine that could be coming from the fuel tank. I don't like the thought of dropping the tank again to replace the $250 fuel pump, but I will pick up pressure gauge and check it. Any idea what the pressure should be?
Thanks...Dan
Jul 13, 2007 at 8:06 AM
2CARPRO JACK
  • 11,533 POSTS
Should be between 41 and 47 psi.
Jul 14, 2007 at 12:49 AM
DGHAHN
  • 6 POSTS
Well, I got further today. Based on a list of things to try I unplugged the MAF and Air temperature sensor, and all of a sudden it ran fine. When I plug either one back in it sputters and backfires on acceleration again. Is it possible that both of these sensors went at once(doesn't seem likely)? Or does this point to a different problem. I also cleaned both sensors with MAF cleaning spray.
I am planning on replacing both sensors, but I'm wondering if this could be a sign of engine control module failure or something else.
Jul 15, 2007 at 7:31 AM
DGHAHN
  • 6 POSTS
I've replaced the MAF sensor and air temperature sensor and it still backfires when accelerating. It idles fine and there are no check engine codes. I'm not sure what the next step may be.
If I disconnect the maf and air temp. sensor it runs much better, but not perfect. Any ideas?
Jul 18, 2007 at 1:14 PM
DGHAHN
  • 6 POSTS
I finally picked up a fuel pressure gauge and checked the pressure. With the key on, but not started the pressure is exactly 50lbs. Once I start the van it fluctuates when I rev the engine between 47 and 52.
You said it should be between 41-47, I was expecting to see lower numbers if there was a problem, but is it a problem if the numbers are higher?
Jul 22, 2007 at 6:32 AM
DGHAHN
  • 6 POSTS
It turned out to be the fuel pump. It took me a while, checking everything but the fuel pump, because I thought I was ok with the comment about 41-47 psi.
But I found another site where someone told me that it should be 58-65. My pump was putting out about 50psi, and I didn't think the slight difference would matter... but it did. It's running great now.
Jul 28, 2007 at 8:29 AM
Suggested Repair
Verify fuel pressure and scan for codes. The owner found about 50 psi, below a 58-65 psi specification from another source, and replacing the fuel pump stopped the hot backfire and lack of acceleration.
Conversation Summary
A 2000 Chevrolet Express 1500 with a 4.3L engine idled normally but backfired, sputtered, and would not accelerate once hot. Plugs, cap, rotor, MAF, and air-temperature sensor work did not fix it, and no check-engine light was present. An expert advised checking fuel pressure, scanning the PCM, and ruling out a plugged exhaust, stating 41-47 psi. Measured pressure was about 50 psi key-on and 47-52 psi running. The owner later reported that the correct range was 58-65 psi and that replacing the fuel pump resolved the problem.
