2001 Chevy Express A/C Cuts Out
COLATECH
I have a 2001 Chevy express with 160,000 miles.
A/C works only for a while when first started. I loose all voltage to the cycling switch. Of course then the compressor will not kick in.Where do the wires go to from the cycling switch? I have swapped the A/C relay.
Aug 10, 2007 at 6:10 AM
CLY
  • 308 POSTS
It looks like the feed for that switch(green wire)comes from the powertrain control module and the black wire splices into the ground curcuit for the compressor. I would have the codes checked and see if maybe the computer is camanding the a/c system off for some reason.Not all codes will turn on the check engine light. You may have a low freon code or something setting...
Cly
Aug 10, 2007 at 9:06 AM
Suggested Repair
Have diagnostic codes checked, including codes that do not turn on the check engine light. The PCM may be commanding the A/C off, possibly because of low refrigerant. The cycling switch green wire is fed from the PCM, and the black wire splices into the compressor ground circuit.
Conversation Summary
A 2001 Chevy Express with 160,000 miles has A/C that works only briefly after startup, then loses voltage at the cycling switch so the compressor will not engage. The A/C relay was already replaced. An expert said the switch's green wire is fed from the powertrain control module and the black wire splices into the compressor ground circuit, and recommended scanning for codes because the computer may be shutting the A/C off, possibly due to low refrigerant.
