2004 Chevy Express Oil Choice
SPAHI77
I have a 2004 Chevy Express Cargo Van
that has the 4.8 L engine, and is a HD rated 2500 version.
The vehicle is being used for construction use, and has about 65,000 miles. Lately its been about 90 degrees here in NYC, and i feel as if the engine is getting to hot, and the car is not driving quite the same. I know on 80's older cars usually at about 70,000 miles i used to go with a 10w-40, and things were fine. however i know engines have changed.
I was wondering, what type of oil should i use for summer, and should i use the 5w-30 in the winter?
Or should i keep the oil the same throughout the year?
Currently i am using a 5w-30 Castrol Startup oil
Jul 10, 2007 at 3:02 PM
  • 75,988 POSTS
[quote:88c79c72d9="Spahi77"]I have a 2004 Chevy Express Cargo Van
Currently i am using a 5w-30 Castrol Startup oil[/quote:88c79c72d9]
My opinion/experiences I'll stay in one grade oil 10W30 or 40 thru out the seasons. When that battery/starter kick that engine over and fires up am gone-Hello coyote bar.lol
Unless you stay in the Artic when you need to heat the oil thru the dipstick so it won't thicken up on you.
I use Pennz oil that's my best of all-yellow bottle!!
For preventive maintenance change it every 2500 miles its good for the internals oh! don't forget the filter that needs changing too.
Good Luck
Aug 25, 2007 at 6:09 PM
Suggested Repair
Use one oil grade year-round, either 10W-30 or 10W-40, rather than switching between summer and winter viscosities. Change the oil and filter about every 2,500 miles. The expert prefers Pennzoil.
Conversation Summary
The owner of a 2004 Chevrolet Express 2500 cargo van with a 4.8L engine and about 65,000 miles, used for construction, asked whether to keep 5W-30 year-round or use a heavier oil in hot weather because the engine seemed to run hot and drive differently. The expert recommended staying with 10W-30 or 10W-40 in all seasons, changing the oil and filter about every 2,500 miles, and preferred Pennzoil.
