Sometimes engine will start and sometimes won't. Mostly when cold is when I have the most trouble. I can spray engine starting fluid and engine will run, but when it burns off starting fluid the engine will die.
I have had it tuned up, changed distributor, changed timing gear and chain, changed catalytic converters.
I have noticed that the manifold pipes fit loose at joint. I put a gauge on the fuel line and it ran at 50 psig at all times.
Can you please give me some advice on what you might think the problem is?
SPONSORED LINKS
Wednesday, January 24th, 2007 AT 3:19 PM
