I just performed a compression test and here is the results:
Cylinder-Compression-----Spark plug Condition
1------------180------------------plug was clean
2------------185------------------Plug was clean
3------------185------------------Plug was clean
4------------175------------------Plug was Clean
5------------150------------------Plug had oil on it
6------------180------------------Plug had oil on it
I read a post that no cylinder should be less than 70% of the highest reading, my sons Van has 215000 miles!
I will do the the next compression test and add one tablespoon of oil in the number 5 cylinder to determine if is the rings or Valves, I also heard that it could be a worn lobe in the Cam shaft.
I tend to think that is coming from Valves because Cylinder number 6 was also wet with oil and it had 180 compression!
Whats your take?
Van is running good now and starting every time!
Jul 24, 2020 at 5:22 AM
(Merged)
