HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Van
Ignition
No Spark
SPONSORED LINKS
1989 Chevy Van No Spark
RMCOYNE
MEMBER
1989 CHEVROLET VAN
V8
2WD
AUTOMATIC
189,000 MILES
New rotor, ignition, fuel pump, coil - still not spark - any suggestions
Saturday, May 24th, 2008 AT 3:57 PM
MECHANIC
Check for power at pink wire at coil and ECM B fuse
SPONSORED LINKS
Saturday, May 24th, 2008 AT 4:16 PM
RMCOYNE
MEMBER
[Checked the pink wire - no power to the large or the small pink wire - fuse is good. Suggestions on where to go from here?
Sunday, May 25th, 2008 AT 10:07 AM
MECHANIC
You have an open circuit from the pink wire that powers the coil to the ignition switch or the switch itself.
Monday, May 26th, 2008 AT 12:15 AM
Please
login
or
register
to post a reply.
Related No Spark Content
Were Driving Van, Stepped On Gas To Get Out Of Drive Quick, Van Just Died. Have Oil Pressure, Changed Cap & Rotor, Had Ignation Module...
Asked by
migelfritz2106
1989
CHEVROLET VAN
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
2000 Chevy Van Have Spark Sometimes And Mostly No...
Went Through Rain Parked Van Afterward It Would Not Start Till Next Day. Started Ran Fine Then Same Thing Till Next Day. Got Her Home...
Asked by
bcruzn
2000
CHEVROLET VAN
1996 Chevy Van Timing
Start From Scratch, How Do You Set The Timing Starting From The Timing Chain If You Know Where Top Dead Center Is At The Crank, But Not...
Asked by
root dr
1 ANSWER
1996
CHEVROLET VAN
1992 Chevy Van Ignition Wirering And Timing
Engine Mechanical Problem 1992 Chevy Van V8 Two Wheel Drive Automatic I Had To Take The Oil Pump Out To Replace The Shaft Guild. I...
Asked by
pita65
1 ANSWER
1992
CHEVROLET VAN
My 94 Chevy G20 Van Keeps Slipping Ing 3rd Gear
My 94 Chevy G20 Van Keeps Slipping Ing 3rd Gear After Its Gets Out Of That Gear Its Fine I Have To Get Pressing On The To Push The Speed Up...
Asked by
gabriel26
1 ANSWER
1994
CHEVROLET VAN
VIEW MORE
SPONSORED LINKS
Ignition System Testing
Ignition Coil System Test Repair - All Cars
Crankshaft Sensor Replacement
Online car repair manuals
