1996 Chevy Van timing
150,000 MILES • V8 • 2WD • AUTOMATIC
ROOT DR
start from scratch, how do you set the timing starting from the timing chain if you know where top dead center is at the crank, but not the cam. when i line up the dots cam at 6, crank at 12 my rotor is not at # 1.
Apr 20, 2008 at 2:45 PM
RHALL77
  • 3,361 POSTS
does your cam and crank line up every time. if yes, that means your distrubitor is off a tooth or two. all you can really do is remove it and adjust it back and fourth till it lines up. just make sure your crank and cam are lined up.
Apr 23, 2008 at 12:29 AM
