1999 Chevy K1500 Window and Wiper Fault
THE PHONE GUY
Good morning, I have a 1999 k1500 extended cab chevy truck. It has 47K miles with a small v8 motor. A few days ago, my drivers side electric window would not go down. Passenger side was ok. The next morning the trouble was gone...Both window were ok. Yesterday, I was driving home and it started to rain lightly. My wind shield wipers would not turn on! Both windows worked ok. I stopped at a store, for 10 minutes, started up again and the wipers were ok! What would cause these intermitent problems?
Sep 29, 2007 at 1:48 AM
MERLIN2021
  • 17,250 POSTS
You may actually have two things going on. First the power window motors have an internal circuit breaker, if they trip they must cool off before they operate again! The second is the multifunction switch may be on the fritz!
Sep 29, 2007 at 4:33 AM
THE PHONE GUY
[quote:a83bcf6074="merlin2021"]You may actually have two things going on. First the power window motors have an internal circuit breaker, if they trip they must cool off before they operate again! The second is the multifunction switch may be on the fritz![/quote:a83bcf6074]
Thanks for the reply Merlin2021. Because both problem happened two days apart, I assumed they were related. The power for the electric windows must go though the igntion switch or I would be able to open and close the windows at any time. The same for the wipers. When I noticed that the window would not work, I had just started the truck after sitting for eight hours. The same when the windshield wipers would not turn on. It it possible that the igntion switch has a intermitent open?
Sep 29, 2007 at 12:30 PM
Suggested Repair
Let the power window motor's internal circuit breaker cool and reset if a window stops working. If the wipers fail intermittently, inspect or replace the multifunction switch. The ignition-switch theory was not confirmed.
Conversation Summary
A 1999 Chevrolet K1500 had an intermittent driver-side power window failure, then a separate intermittent windshield-wiper failure; both returned to normal after a short time. The expert said the window motor may have an internal breaker that must cool before it works again, and that the multifunction switch may be failing. The owner asked whether an intermittent ignition switch could explain both symptoms, but that was not answered.
