The driver power window is down on my '94 Lumina 4 door sedan and is no longer working. How do I get it back up manually. I want it up until I find a new control switch for it. The passenger window does not work either but is up.
The back windows work.
Thanks for any help!
SPONSORED LINKS
Friday, September 7th, 2007 AT 3:56 PM
MERLIN2021
MECHANIC
You will need to remove the door panel then the window motor, then pull up on the glass, then either brace it or put the motor back on so the glass stays up!
