1994 Chevrolet 1500 Rear Knock
FSR57
1994 chev 1500.5.7 350,auto 161,000 oil pressure is great,no missing,noise from rear of engine.was told it was rear main bearing,can i replace this with engine in truck,? any help thanks
Apr 29, 2007 at 12:14 PM
  • 75,988 POSTS
[quote:e60ad73503="fsr57"]1994 chev 1500.5.7 350,auto 161,000 oil pressure is great,no missing,noise from rear of engine.was told it was rear main bearing,can i replace this with engine in truck,? any help thanks[/quote:e60ad73503]
Yeap! go underneath-get an old 350 book and follow it with the trick on a cotter pin.
Apr 29, 2007 at 7:27 PM
FSR57
[quote:f42e076357="rasmataz"][quote:f42e076357="fsr57"]1994 chev 1500.5.7 350,auto 161,000 oil pressure is great,no missing,noise from rear of engine.was told it was rear main bearing,can i replace this with engine in truck,? any help thanks[/quote:f42e076357]
Yeap! go underneath-get an old 350 book and follow it with the trick on a cotter pin.[/quote:f42e076357]
explain the trick with cotter pin ,u lost me?
Apr 30, 2007 at 2:40 AM
  • 75,988 POSTS
[quote:d849e20ba9="fsr57"][quote:d849e20ba9="rasmataz"][quote:d849e20ba9="fsr57"]1994 chev 1500.5.7 350,auto 161,000 oil pressure is great,no missing,noise from rear of engine.was told it was rear main bearing,can i replace this with engine in truck,? any help thanks[/quote:d849e20ba9]
Yeap! go underneath-get an old 350 book and follow it with the trick on a cotter pin.[/quote:d849e20ba9]
explain the trick with cotter pin ,u lost me?[/quote:d849e20ba9]
Remove the bearing cap, bend both the tail end of the cotter pin atleast qtr in. stick the head in the journal's oil hole this will help to remove the upper bearing
Apr 30, 2007 at 7:54 AM
FSR57
[quote:129bb0ab2a="rasmataz"][quote:129bb0ab2a="fsr57"][quote:129bb0ab2a="rasmataz"][quote:129bb0ab2a="fsr57"]1994 chev 1500.5.7 350,auto 161,000 oil pressure is great,no missing,noise from rear of engine.was told it was rear main bearing,can i replace this with engine in truck,? any help thanks[/quote:129bb0ab2a]
Yeap! go underneath-get an old 350 book and follow it with the trick on a cotter pin.[/quote:129bb0ab2a]
explain the trick with cotter pin ,u lost me?[/quote:129bb0ab2a]
Remove the bearing cap, bend both the tail end of the cotter pin atleast qtr in. stick the head in the journal's oil hole this will help to remove the upper bearing[/quote:129bb0ab2a]ok thanks i got it
Apr 30, 2007 at 9:38 AM
Suggested Repair
The rear main bearing can be replaced with the engine in the truck. Work from underneath using a 350 service procedure: remove the bearing cap, bend both cotter-pin tails at least a quarter inch, and insert the pin head into the journal oil hole to help remove the upper bearing.
Conversation Summary
The owner of a 1994 Chevrolet 1500 with a 5.7L 350 and 161,000 miles reported a rear-engine noise with good oil pressure and no misfire, and asked whether a suspected rear main bearing could be replaced in the truck. The expert said yes, from underneath, following an older 350 manual and using a cotter pin. After clarification, the expert explained bending the pin tails and inserting the head into the journal oil hole to remove the upper bearing. The owner confirmed they understood.
