No lights on rear of truck when headlights are turned on
B-EAZY1869
I have a 1993 Chevrolet K-1500, 4x4, Automatic Transmission with a 5.7L, 350cid v-8 throttle body fuel injection. The truck has approx. 260,000 miles on it. When I turn the headlights on, the whole rear of the truck stops working, no turn signals, no brake lights, and no license plate lights. But when the head lighs are off everything works fine, but if you engage the turn signals no matter which way you select and then hit the brake pedal, the flasher starts to blink at a medium speed, (not as fast as with a blown bulb, but faster than normal) and as soon as you let off the brake it slows down to normal speed. Is there something I should be looking for other than a ground malfunction, if so or if not where should I start looking? Please help hair is getting thin......... Head lights always work and the bulbs in haven't been changed in 3 years and this just started happening a week or so ago.
Nov 23, 2007 at 10:00 AM
MERLIN2021
  • 17,250 POSTS
three possiblities, 1,) you have the wrng bulb in 1 or more sockets back there, or 2.) you have a wiring problem, grounded power...last switch is bad I don't think that's it, headlights always work?
Nov 23, 2007 at 10:14 AM
JASON R
  • 10 POSTS
i had an issuce close to this one.whenever i put my truck into reverse the passenger tailight stopped working.Or when i braked.It sounds like a faulty lightboard.dumb things go all the time.I backed into a tree and it works fine now.
Take out a tailight.the whole assembly.If im not mistaken there should be a board holding the bulbs.Pull it off.You should see a black and silver board.The board is partially see through.If its bad youll see a greenish powder around the connections.
Nov 26, 2007 at 4:06 AM
