1994 Chevy Truck headlights
192,378 MILES • 6 CYL • 2WD • MANUAL
CARSAR
low beams do not work. high beams work good???
Feb 6, 2008 at 8:41 AM
MASTERTECHTIM
  • 4,750 POSTS
if the bulbs are good i would look at the dimmer switch. its located at the base of the steering column.
Feb 6, 2008 at 8:44 AM
CARSAR
changed dimmer switch did not work, now what??????????????????????????????? [quote:55fbe9c2db="mastertechtim"]if the bulbs are good i would look at the dimmer switch. its located at the base of the steering column.[/quote:55fbe9c2db]
Feb 11, 2008 at 5:34 AM
MASTERTECHTIM
  • 4,750 POSTS
i did not mean replace the switch, i meant try testing for voltage there. the headlight switch sends 12 v to the dimmer switch then depemding on whether it is on high or low determines which wire gets power from there. so use a test light to ground and probe the 3 wires at the dimmer switch. one wire should be hot when lights turn on, this is power in, a different wire should have voltage on high beam and the other wire will have power on low beam. if that is good then you must trace the wire for a open from the dimmer switch to the headlight bulb
Feb 11, 2008 at 8:39 AM
