1969 Chevy C-10 Low Compression Idle
then you can adjust the exhaust valve. You can go through and do all intake then exhaust or you can work cylinder by cylinder. Be careful when you do this as it takes a light touch sometimes to feel when the rod gets resistance, try this part a few times till you get the feel of it. if you are unsure about this you can adjust with motor running but is very messy. With valve cover off let motor idle and back off rocker nut until it starts to tap and then tighten till tapping stops and give 1/2 - 3/4 turn more and you should be set. :shock:
Suggested Repair
Recheck hydraulic lifter adjustment with the EOIC method: with the exhaust just starting to open, set the intake to zero lash then add 1/2 to 3/4 turn; with the intake fully open and just starting to close, set the exhaust the same way. Alternatively, with the engine idling and the valve cover off, loosen each rocker until it taps, tighten until the tap stops, then add 1/2 to 3/4 turn. Low compression on two cylinders may still need further diagnosis if adjustment does not restore idle.
Conversation Summary
A 1969 Chevy C-10 with a 400 small block ran acceptably until gasket work, then idled roughly and would not hold idle. Compression was very low on two cylinders, raising questions about bad rings or incorrectly tightened lifters. The expert explained hydraulic lifter adjustment using the EOIC method or a running-engine method, setting 1/2 to 3/4 turn of preload after zero lash.
