HELP 1994 Chevy 1500 Running Rough Speeds below 40 MPH
MIT
  • 1994 CHEVROLET TRUCK
My truck has 185,000 miles (5.7 L V8 ) on it now and it has been ideling rough when in gear for some time now, but it's started sputtering at speeds less than 40 MPH, it's the worst at less than 30 MPH. Also, I have noticed on the highway it is missing a little bit at speeds around 70 MPH. I have recently changed the distributor, rotor and wires, but havent had a chance to replace the plugs yet. I also have with in the last 2 years replaced the fuel pump with regulator and a fuel filter.
Any ideas?
Wednesday, September 12th, 2007 AT 10:49 AM
2CARPRO JACK
  • 11,533 POSTS
Do the plugs. While they are out, do a compression test to be sure you arent trying to tune out a low compression issue. Be sure to use quality parts when you tune it up. NO Bosch Platinum (A/C Delco or Autolite) plugs
Monday, September 24th, 2007 AT 7:45 AM
