fuel system
TINKER33
i have replaced the fuel pump, wireing harness, and filter. I am getting fuel to the engine but wont stay started, have to put fuel in the carb. but wont start once that fuel is burned up. what else could it be and how to fix. its a 1996 chey. 1500 4.3 engine
Mar 18, 2007 at 5:25 AM
KIN CHAN
  • 453 POSTS
check engine lite came on ?
- this is an OBD2 car ... can't treat it like a carburetor 86' chevy p/u ... u ECM gotta get signals from the cam and crank then it fire the ignition and injectors on the TBI....
Mar 18, 2007 at 8:20 AM
TINKER33
this is a throttel body injection type vehicle. this is truck and its a straight cab. no check eng. light on we put eveythign back on and still will not start
Mar 18, 2007 at 8:48 AM
KIN CHAN
  • 453 POSTS
u must verify if ur ECM is getting cam & crank signal 1st then if it does ..u continue to chk if ur injectors are getting signal on / off by the ECM....fixed tons of these TBI gm truck in the past...should be straight forward...
Mar 18, 2007 at 8:55 AM
AUTOPOP
  • 49 POSTS
Don't forget to check on fuel pump circuit ground and fuel pump relay.
May 18, 2007 at 4:13 AM
