1992 Chevy K1500 Vent Arrows Flash
DRLIVING
I have a 1992 Chev K 1500, 350 ci, 65k miles. When I turn on the heater, the vent arrows flash for about 1 minute then stop. I can't move the air flow from floor to defrost, but air blows out the vents. It doesn't matter if its heat or a/c. Is the flashing a electrical code or is it a vacuum line under the dash that is leaking or broken?
May 14, 2007 at 10:46 AM
2CARPRO JACK
  • 11,533 POSTS
No vacuum in there. Disconnct the plug to the blend actuator, check for voltage, should be 6-7.5 , if lower replace controller, if in range replace the actuator
May 15, 2007 at 4:04 AM
Suggested Repair
Disconnect the blend actuator plug and check voltage; it should be about 6 to 7.5 volts. If voltage is lower, replace the controller. If it is in range, replace the actuator. This is not a vacuum-line problem.
Conversation Summary
The owner of a 1992 Chevrolet K1500 says the climate-control vent arrows flash for about a minute, then stop, and airflow cannot be switched from floor to defrost although air still blows. The expert says there is no vacuum issue and advises checking blend actuator voltage, then replacing the controller if voltage is low or the actuator if it is in range.
