1998 Chevrolet Cavalier No Spark
EMAREL76
Just replaced the head gasket, and timing chain w/gears. Before the gasket & chain replacment I was getting fire from the ignition wires, now I'm not. Checked all wiring connections, took off hte module and had it tested, looked up a wiring schematic to test the posative and negative leeds. Checked the conection to the crank sensor. I'm at a total loss on what the problem could be. Somebody please help.
Feb 10, 2007 at 7:11 AM
CHEVY22
  • 1,375 POSTS
have you checked the obvious like , a dead battery , loose connections or other connections you pulled off to do the job that didnt go back , check again i think you may have missed a couple of wires, i have been doing this stuff a long time and when i hurry i always miss one
jim
Feb 16, 2007 at 4:55 PM
COMPASS AUTO
  • 10 POSTS
A 98 Cav. has 2 crank sensors one in the side of the block between tranny & motor, the other is behind the crank pulley I would check to see if you damaged it during removal or instalation of crank pulley.
Mar 10, 2007 at 12:52 PM
Suggested Repair
Recheck the battery, loose connectors, and any wiring left disconnected after the timing job. Inspect both crankshaft position sensors, especially the one behind the crank pulley, which can be damaged during pulley removal or installation.
Conversation Summary
The owner of a 1998 Chevrolet Cavalier lost spark after replacing the head gasket and timing chain and gears, despite previously having spark. Wiring, the ignition module, and a crank sensor connection had already been checked. Replies suggest missed connectors and possible damage to one of the two crank sensors, particularly the sensor behind the crank pulley.
