1995 Chevy Corsica Won't Start
DAWNE19
i know nothing about cars-just to start off...
i had my alternator replaced in april, then in may it seemed to stop working again. Took it to my mechanic, and he couldn't figure it out, and replaced it free of charge. Its now 2 months after the second installation and it seems like it has gone again. Once I pop the hood and have it open for a few minutes it starts fine. Also when i have left for several hours or overnight it starts without a problem. Is it possible it has something to do with the alternator and it overheating?? I don't know if this means anything or if it even should be, but once it does start the fan at the front is not running-engine fan. I don't know if it a constant running fan or just at certain times.
PLEASE ANY ADVICE BEFORE I TAKE IT TO THE MECHANICS AGAIN!!!!!!!!
Jul 6, 2006 at 5:56 AM
MIKEYBDMAN
  • 623 POSTS
What are the symptoms? Wont start? Shuts off? Do you have a amp gauge on your dash board?
Jul 8, 2006 at 8:44 AM
DAWNE19
once the engine is turned off--sometimes not always-- it just won't start again, everything turns on a click and thats it..... I open the hood, it sits for a bit, and then it starts without a problem. It's very inconsistant!!
Jul 8, 2006 at 11:57 AM
MIKEYBDMAN
  • 623 POSTS
Ok, I would take it to your local parts dealer, and have them test your charging system. If it is not charging, then you might want to try another place for getting your altenators.
Another good thing to look for is the ground cable from the battery to the engine block. This cable can get corroded and cause all sorts of problems. Have someone try and start the car while you are pulling on the cable. Hopefully you will find a solution soon.
Jul 8, 2006 at 12:49 PM
Suggested Repair
Have the charging system tested at a parts store. If it is not charging, consider getting the alternator from another source. Also inspect the battery-to-engine ground cable for corrosion, and have someone try to start the car while the cable is moved to check for a bad connection.
Conversation Summary
The owner of a 1995 Chevy Corsica reports an intermittent no-start after two alternator replacements. The car sometimes only clicks until the hood is opened and it sits, then starts; it also starts fine after sitting overnight. The engine fan does not run after startup. The expert recommends testing the charging system and checking the battery-to-engine ground cable for corrosion.
