1993 Chevrolet Cavalier No Start
SPEED_BUMP
I have a 93 chevy cavalier w/ a 2.0l engine and 123000 miles. Car cranks, has good compression and good spark, but will not start. When ignition key is turned to run position, the fuel pump runs longer than normal, about one minute or longer before shutting off. After cranking, the fuel pump continues to run for about 30 seconds. I replaced the fuel filter and the old filter was very restricted, still no start. I sprayed starting fluid into the throttle body and the engine started for a few soconds then died. Please give advise
Thank You
Speed_bump
Mar 4, 2006 at 10:28 AM
NOS
  • 320 POSTS
it sounds to me like you have lost your fuel pump. if you use anything to start your car don't use starting fluid use choke cleaner. starting fluid is real dangerious it can lock your motor up till you pull the plugs out and that stuff hangs around longer than i like if you motor happen to spark for any reason it could burn you very serously. i almost lost my eye sight due to someone useing starting fluid. if you can get your hands on a fuel pressure guage check pressure. if the filter was as cloged as you sya i bet it is fuel pump which my friend is in the tank if i remember right the pressure should be right at 35 psi any less won't fly. hope this helps. (NOS)
Mar 8, 2006 at 4:18 PM
Suggested Repair
Check fuel pressure with a gauge; it should be about 35 psi. A very restricted filter plus a no-start with spark and compression points to a weak or failed in-tank fuel pump—replace the pump if pressure is low. Do not use starting fluid; it is hazardous.
Conversation Summary
A 1993 Chevrolet Cavalier 2.0L cranks with good compression and spark but will not start. The fuel pump runs longer than normal, a very restricted fuel filter was replaced with no change, and starting fluid only ran the engine briefly. The expert advised checking fuel pressure near 35 psi, suspected a failed in-tank fuel pump, and warned against using starting fluid.
