2005 Chevy Aveo Stalls When Slowing
Thanks for your reply
Suggested Repair
The idle air control (IAC) can cause stalling at idle or when letting off the gas, which fits the described symptoms. Because the low-mileage vehicle is likely under warranty, have the dealer diagnose and repair it.
Conversation Summary
The owner of a low-mileage 2005 Chevy Aveo reported stalling twice on short trips, especially when slowing or turning, with the engine sounding as if it was not getting fuel despite a mostly full tank. Restarts took several minutes, and the car would not start in gear or neutral. The owner asked whether the IAC or EGR could be involved. The expert said the IAC can cause the engine to die at idle or when letting off the gas and recommended letting the dealer handle it if the car is under warranty. The owner thanked the expert and said they needed to get the car to the dealer safely.
