2002 Chevrolet Cavalier Shuts Off
JM240000
:cry: I have a 2002 chevy cavalier purchased it about 6 months ago. It has about 96000 miles on it. If I get on the highway going 65 t0 70 mph after going about 100 miles the car just loses power and shuts off. It may crank after 3-5 minutes but I may only get 5 miles down the road and it die again. It took
me 13 hours to get 200 miles. I have had the fuel
pump checked, was told it was fine, had the gasoline
filter and transmission filter changed. I am told by different mechanic that every thing is fine. Could it be that maybe a module needs to be checked or
what could it be?
Mar 21, 2006 at 3:13 PM
JM240000
[quote:00e35c323e="jm240000"]:cry: I have a 2000 chevy cavalier purchased it about 6 months ago. It has about 96000 miles on it. If I get on the highway going 65 t0 70 mph after going about 100 miles the car just loses power and shuts off. It may crank after 3-5 minutes but I may only get 5 miles down the road and it die again. It took
what could it be?[/quote:00e35c323e]
Mar 21, 2006 at 3:22 PM
MVANNESSJR
  • 223 POSTS
Does it lose complete power? Lights, dash panel, etc? Everything shuts off?
Check the battery connections for corrosion. Make sure they have good contact. Total system shutdown is usually the result of a lose or bad connection to the battery or alternator... Something in the circuit isn't making great contact.
Mar 22, 2006 at 1:28 PM
Suggested Repair
Check the battery connections for corrosion and poor contact, and inspect the alternator circuit connections. A complete shutdown is often caused by a loose or bad battery or alternator connection.
Conversation Summary
The owner of a 2002 Chevrolet Cavalier with about 96,000 miles reports that after roughly 100 miles at 65-70 mph the car loses power and shuts off. It may restart after 3-5 minutes, then die again within a few miles. The fuel pump was checked and reported fine, and the fuel and transmission filters were replaced, but mechanics found nothing wrong. The expert asks whether lights and the dash also go out, and advises checking battery connections for corrosion and good contact, noting that total shutdown is often a loose or bad battery or alternator connection.
