and it still dosent start after a number of trys i noticed that my gas meter still was reading empty.and i know that i have at least (7) gallons
my car ended up being towed to my house.
please help me what cqan be the problem :cry: [/b]
Check fuel pressure before replacing the fuel pump. If there is no pressure, the in-tank pump may have failed after the tank ran dry. Confirm that before replacement, since the pump is not a quick or inexpensive first step. If pressure is present, check other no-start requirements such as spark.
A 2002 Chevrolet Tahoe ran out of fuel on the freeway. After several gallons were added, the engine cranked but would not start, and the fuel gauge still read empty. The owner had also noticed reduced power beforehand and asked whether the fuel pump should be replaced. The expert said running dry may have damaged the in-tank pump, but recommended checking fuel pressure first and considering replacement only if pressure is absent. If pressure is present, diagnosis should move to other systems needed for starting.
