1996 Chevy Tahoe Daytime Running Lights
GMC
PBURGOS
I have a 96 chevy Tahoe, my daytime running lights don't go on. My Highbeams and lowbeams work.
The green DTR light on the dash is on but the lights are off, I was told that their is a way of turnning them on/off is this true?
Mar 7, 2006 at 12:32 AM
NOS
  • 320 POSTS
yes make sur you emrgenacy brake is completely off if it is set one notch it will turn off the daytime running lights (NOS)
Mar 8, 2006 at 3:59 PM
Suggested Repair
Make sure the emergency brake is fully released. If it is set even one notch, it can turn off the daytime running lights.
Conversation Summary
The owner of a 1996 Chevy Tahoe says the daytime running lights do not come on, although the high beams and low beams work and the green DRL dash light is on. They also asked whether the lights can be turned on or off. The expert said to confirm the emergency brake is completely off, because setting it one notch will disable the daytime running lights.
