electrical short in tail lights of 1992 chevy g20 van
1992 GMC
B1XHIV29
I have a electrical short in the running lights of my 1992 chevy G 20 van. where is the best place to start looking.
Jan 17, 2006 at 10:44 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Please specify which running lights are affected (front, rear, marker/side), whether any fuses are blowing or bulbs failing, whether the short is constant or intermittent, and list any diagnostic findings you already have.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
ARKOSE
  • 19 POSTS
You can start at the light or the fuse box, whichever is easiest to get to. Check for tight connections and undamaged wire. Check your resistance to ground. That should give you a good starting point.
Jan 20, 2006 at 6:38 AM
Discussion summary
The owner of a 1992 Chevy G20 van reported an electrical short in the running lights and asked where to begin troubleshooting. A respondent recommended beginning at the light or fuse box and cited wiring, connections and grounding as potential areas of concern; those comments are suggestions and were not confirmed by the owner.
Reported outcome: The owner did not report any diagnostic results or a repair outcome.
No diagnostic data were provided (no affected-circuit identification, fuse or bulb status, wiring-visuals, measurements, or photos). The single reply offers suggested starting points only and is unconfirmed by the owner.
Read the original discussion
