2000 Chevy Tahoe Fuel Pump/Injector?
2000 CHEVROLET TRUCK
DUANEHORNE
When I turn the key to start the truck a whizzing noise has started that I have been told may be the fuel pump or injector going out. The truck does not turn over easily now and I was told not enough gas is getting into the carbeurator for it to start quickly. Is it fuel pump or fuel injector and how much does it generally cost to get repaired including labor? Thanks.
Feb 4, 2006 at 2:06 AM
SC1 RACING
  • 117 POSTS
if the truck isnt turning over as good it may be a starter problem. it will also make a whinning noise.
first id recomend testing starter before you spend unnecasary money.
Feb 4, 2006 at 4:01 AM
