1999 Chevrolet Tahoe Rear Vibration
BLAZERRF88
99 chevy tahoe 114,000 miles
Irecently replaced the ujoints on the driveshaft and still have a vibration coming from the rear of the vehicle. could this be a wheel bearing or is there something else I should look at first? I did line up the driveshaft by marking the joints before I removed it and I did not lose any of the weights. would appreciate any help I can get
Thanks
Jul 30, 2006 at 1:34 PM
DEMEARSJR
  • 110 POSTS
To check your wheel bearings raise the rear end of the vehicle and put 1 hand on the top of the tire and 1 hand on the bottom.
If it wiggles it's a bearing.
Look for uneven tire wear as well.
Jul 30, 2006 at 4:21 PM
Suggested Repair
Raise the rear of the vehicle and check the wheel bearings by placing one hand on the top of the tire and one on the bottom. If the wheel wiggles, the bearing is bad. Also inspect the tires for uneven wear.
Conversation Summary
The owner of a 1999 Chevrolet Tahoe with 114,000 miles has a rear vibration after replacing the driveshaft U-joints. The shaft was marked for alignment and the balance weights were not lost. The expert recommends checking the rear wheel bearings for play and looking for uneven tire wear.
