2000 Chevy Truck starter failure
2000 CHEVROLET TRUCK
165,000 MILES • V8 • 4WD • AUTOMATIC
CJHAMILTON
replaced transmission, power to the nuetral safety swicth but no power to the starter
Dec 7, 2008 at 2:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Power will come from the battery, through a fuse box if equpped and to the starter. The secondary source will come from the ignition switch when you turn your key. The best way is to chase down the power loss from the two sources to find out where there is a loss at, most likely a fuse/relay or short in wires. May also be equiped with anti-theft shut off system. This too will have a relay.
Dec 7, 2008 at 3:11 PM
