Electrical problem
1996 Chevy Truck V8 Two Wheel Drive Automatic
replaced starter, have to hold key on for several minutes before engine will crank. Can you help?
Friday, October 22nd, 2010 AT 11:19 AM
MECHANIC
Have to hold key on for several minutes before engine will crank
Did you meant you have to hold key at cranking position then it will crank engine over or before the engine starts? Clarify
SPONSORED LINKS
Saturday, October 23rd, 2010 AT 1:19 AM
PROSONE
MEMBER
I have to hold key on in the start position for several minutes before engine will crank. Turning the key to start position nothing happens, I hold key in that position for several minutes before starter will crank the engine over.
Saturday, October 23rd, 2010 AT 6:36 AM
MECHANIC
Check the battery and connections if its good - try shorting out the starter motor if it cranks the egnine over w/o lagging-test the ignition switch
