1999 Chevy Truck Compressor Replacement
1999 CHEVROLET TRUCK
240,000 MILES • V8 • 2WD • AUTOMATIC
WEDGEHEAD
How much oil do I add to the system when replacing the compressor, drier and orifice tube after flushing the system? Does it all go in the compressor or do I need to add some to the drier also?
Thanks
Mar 23, 2010 at 4:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
when replacing the compressor you fill the compressor itself with oil then recharge the system. up to 120 ml of oil can collect in the crankcase. when you replace the compressor, drain and measure the old compressor crankcase oil. discard the oil after recording the amount. all replacement compressors are shipped dry and should come with instructions on adding the oil.
Mar 23, 2010 at 11:36 PM
