1999 Chevy Cavalier Battery Won't Charge
DECOY
My 1999 Chevy Cavalier 2.4z is having major power problems. First after about 2 weeks of having the car the battery stopped holding a charge and needed to be jumped each time to start it. Mechanics noticed the alternator wasn't putting out the proper voltage. So I had the battery replaced and the alternator. Now I'm having the same problem. Battery will not charge and I'm getting ABS and Battery light coming on then lights start flickering, windows become sluggish and power is low to everything. Any ideas?
Jul 7, 2006 at 5:08 AM
MIKEYBDMAN
  • 623 POSTS
Check your ground cable from the battery to the engine block. This cable tends to corrode, and can cause major charging issues.
The charging system on a car is very simple. You have a new battery and a new altenator, so lets eliminate those.
Take your car to advanced or napa and get them to test your charging system. I imagine they will say it is charging fine, which usually means you have either a bad or intermittent connection, or something is drawing off of the battery when it isnt supposed to me.
If the ground to the engine is good, and your system appears to be charging correctly, put a volt meter on the battery with the ground cable disconnected. See what volts it reads, then connect the ground terminal back up. It should read the same volts with the ignition switch off and all lights off. If it is lower, you have something draining the battery while it is not running.
Jul 7, 2006 at 12:00 PM
Suggested Repair
Inspect the battery-to-engine ground cable for corrosion or a poor connection. Have the charging system tested; if it charges normally, check for an intermittent connection or a parasitic drain by comparing battery voltage with the ground cable disconnected and reconnected, ignition and lights off.
Conversation Summary
A 1999 Chevy Cavalier still will not hold a charge after a new battery and alternator. ABS and battery lights come on, lights flicker, and electrical accessories lose power. The expert recommends checking the engine ground cable, confirming charging-system output, and testing for a parasitic battery drain.
