Generator light woes
CHEVYRIDER71
  • CHEVROLET TRUCK
OK, the generator light come on in my '71 C10.I changed the alternator, belt, and put a hot battery in and the light comes on until I get the RPMs up and it goes off until I either shut the engine off or if I put it in gear and roll a little forward or reverse. It has an external regulator. Could this be the problem all along and if it is, how can I check?
Monday, November 19th, 2007 AT 10:17 PM
It sounds like your EVR contacts burned-out replace it-its not gonna do you good adjusting it.
Tuesday, November 20th, 2007 AT 2:48 AM
