1998 blazer air bag light?
1998 CHEVROLET TRUCK
DCHRIS1981
  • 12 POSTS
on my 98 chevy blazer the dash light for the air bag's
will come on for a while then shut off as i drive. dose that mean anything or is that normal ? This is the first truck/car that i have owned with air bag's .
Apr 2, 2006 at 5:51 AM
LOSONE
  • 1,616 POSTS
The clock spring is a common problem. It is the the rotating joint between the steering wheel and the airbag circuit.
If the light came on you have set an SRS code. get soemone to read the code and see what the problem might be Good Luck
Apr 2, 2006 at 6:19 AM
DCHRIS1981
  • 12 POSTS
[quote:34b87f90e4="losone"]The clock spring is a common problem. It is the the rotating joint between the steering wheel and the airbag circuit.
If the light came on you have set an SRS code. get soemone to read the code and see what the problem might be Good Luck[/quote:34b87f90e4]
I'll have that checked out thanks!
Apr 2, 2006 at 6:40 AM
