HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Truck
Engine
Symptoms
Not Running
1997 Chevy Truck will not start
CHEVY PROBLEM
MEMBER
1997 CHEVROLET TRUCK
V8
4WD
AUTOMATIC
120,000 MILES
Starts when warm but not in the cold
Tuesday, December 4th, 2007 AT 8:42 PM
PEAR69
MECHANIC
Check your coolant temperature sensor and your Air temperature sensor.
BTW how does it get warm if it doesn't start when cold?
SPONSORED LINKS
Wednesday, December 5th, 2007 AT 1:12 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Chevy Truck Truck Turns Over But Won't Start
I Have Never Had A Problem Starting My Truck Until The Past Year. The Initial Issue Was That It Would Have To Turn Over For About 5 Seconds...
Asked by
mbiles
1 ANSWER
1997
CHEVROLET TRUCK
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1997 Chevy Truck Engine Will Not Start
Engine Will Turn Over, Have Spark At Plug Wire. Can Here Fuel Pump Running. After Cranking Motor And Letting Go Of Key The Crank Will Go...
Asked by
roaddog9385
1997
CHEVROLET TRUCK
Will Not Start Without A Prime
I Have A 1997 Z-71 With A 5.7 Throttle Body. All Original Under The Hood With 245,000 Plus Mileage. I Used To Be Able To Just Tap The Key...
Asked by
timmmy k
1997
CHEVROLET TRUCK
1997 Chevy Truck Engine Not Firing
Had To Replace Heads And Intake Gasket On My 97 Chevy Truck. The Engine Will Turn Over, But It Will Not Fire. New Plugs, Plug Wires...
Asked by
johnna18
1997
CHEVROLET TRUCK
1997 Chevy Truck No Start No Spark
My Truck Will Not Start, I Parked It For A Period Of Time Approx. 2 Mos And Now It Wont Start, I Have Good Fuel Pressure And Have Replaced...
Asked by
vinsonguy
1997
CHEVROLET TRUCK
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
