1997 Chevy Truck Starter
1997 CHEVROLET TRUCK
107,229 MILES • V8 • 4WD • AUTOMATIC
TUTEUL
how do you change the starter on a z71 chevy truck
Jan 11, 2008 at 3:43 PM
MASTERTECHTIM
  • CAR REPAIR CONTRIBUTOR
  • 4,750 POSTS
first disconnect the negative battery terminal. remove the 2 nuts on the starter solenoid then remove the 2 wires, one will be real fat and the other one small. then remove the 2 starter mounting bolts. the starter will come right out. do the reverse to install. hope this helps.
Jan 11, 2008 at 3:47 PM
