1997 Chevy Truck Brakes are grabbing
BALLPLAYERMARK
Brakes problem
1997 Chevy Truck V8 Two Wheel Drive Automatic 200K miles
This weekend I changed the rotors and pads. When I used a c-clamp to depress the caliper pistons they were very hard to depress. Once everything was back together I took it for a test drive and noticed that the brakes seemed to have a little bit of pressure being applied to the from brakes(the pedal felt fine). After driving for less than 10 minutes on the freeway I noticed smoke from the front-end. Upon stopping, I noticed that the brakes were glowing red hot. I pulled the cover on the brake fluid and noticed that the rubber seal was severely deformed. I assume from excessive temp. of the fluid.
Any idea what could be causing pressure to be applied?
Nov 12, 2008 at 12:45 AM
  • 75,988 POSTS
Could be jammed or corroded caliper piston/s or collasped brake hose
Nov 12, 2008 at 1:05 AM
BALLPLAYERMARK
I replaced the calipers, rotors, and pads, andled the brakes. Prior to putting the wheels on I tried to spin the rotors. Same problem - locked up tight.
Nov 12, 2008 at 8:20 AM
  • 75,988 POSTS
Do you have ABS
Nov 12, 2008 at 6:44 PM
BALLPLAYERMARK
Problem solved. I was able to bleed the line at the caliper which released the pressure. I then pumped them back up and bled the line at the master cylinder, which also released the pressure(at this point I knew that everything was ok from the calipers, thru the ABS system, and up to the master cylinder). I then replaced the master cylinder and everything is working perfectly. This seems like an unusual symptom for a master cylinder, as the reverse is usually true (a loss of pressure). thanks.
Nov 13, 2008 at 5:00 AM
