I own a chevy 1500 it is leaking coolant in the cab on the floor of the passenger side. What is it leaking from?
Thursday, May 8th, 2008 AT 12:16 PM
RHALL77
MECHANIC
Sounds like it could be a heater core.
SPONSORED LINKS
Thursday, May 8th, 2008 AT 12:42 PM
PRODRIGU
MEMBER
Its probably your heater core inside the cab. Disconnect your heater hoses to the cab and it should take care of the leak. You will have to tear it apart and replace the heater core to fix it before it gets cold again.
