coolant leak from back of the engine
1998 CHEVROLET TRUCK
134,000 MILES
MIKEFLACH91
I rebuilt my engine from the heads up because it was leaking coolant in the back of the engine. It is a 350 5.7l vortec in my 1998 chevy k2500. I changed the head gaskets and the upper and lower intake manifold gaskets and it still is leaking. it appears to be leaking down rite where the starter is and some streaming down the side of the tranny. My main question is does my year of engine the 98 5.7l 350 have freeze plugs in the back of the engine? Could that be my problem? And if not what else can i look for as a potential leak?.
May 3, 2013 at 7:17 AM
MIKEFLACH91
And forgot to say that I checked the freeze plug above the starter but the leak is coming from higher than that
May 3, 2013 at 7:23 AM
insert a dye in the system and use an ultraviolet light to pinpoint the leak.
May 3, 2013 at 11:58 PM
