1995 Chevy Truck won't start
1995 CHEVROLET TRUCK
HORSESHOER
Engine Mechanical problem
1995 Chevy Truck V8 Two Wheel Drive Automatic
getting gar to trottle body on truck but no gas in trottlle body
Jun 30, 2010 at 1:35 AM
INTERNETMECHANIC
  • 700 POSTS
Can you give us the truck model? Without the rpm signal, there may be no injector pulse. You could use a noid lite on the injector plug, it should pulse, engine cranking. You have spark at the plugs, engine cranking? Did you use a gage and check fuel pressure? Any applicable trouble codes?
Jun 30, 2010 at 4:21 AM
