1995 Chevy Truck White smoke tail pipe
1995 CHEVROLET TRUCK
255 MILES • V8 • 2WD • AUTOMATIC
CALLEY51
What could be causing these problems?
Blowing white smoke, lack of power, slow shifting.
Jan 25, 2009 at 12:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
White smoke from exhaust indicates coolant leaking into combustion chamber and being burnt out the exhaust. Normally caused by a cracked head or intake gasket. Check your coolant level and see if it is low. If it is, need to have engine inspected at reputable repair shop to see what is damaged.
Thanks for using 2CarPros.com!
Jan 25, 2009 at 1:24 PM
