1995 Chevy Truck
SWANY1967
  • 1995 CHEVROLET TRUCK
Engine Performance problem
1995 Chevy Truck V8 Four Wheel Drive Automatic
Truck will start then stop immediately. No vaccum leaks. After it key on pump comes on start truck then dies, after trying to start numerous times within 10 mins it will finally start and runs great. On each attempt it will run a little longer. Something is not letting pump keep up pressure intially? Why after numerous attempts it will run fine? Seems like it is losing pressure. Any input please. Already spent few hundred dollars on injectors and filters.
Wednesday, September 2nd, 2009 AT 5:16 PM
Check and test the oil pressure sending unit this is the one that powers the fuel pump after the initial priming of the fuel system 2secs trime-the switch closes when oil pressure is above 4psi and powers the fuel pump.
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_96.gif
Wednesday, September 2nd, 2009 AT 5:22 PM
SWANY1967
Can I bypass the oil pressure switch to test or should I put a meter on it?
Wednesday, September 2nd, 2009 AT 6:16 PM
Use the multimeter on it
Wednesday, September 2nd, 2009 AT 7:33 PM
SWANY1967
Okay I will test in the morning and let you know.
Wednesday, September 2nd, 2009 AT 7:49 PM
Or find the fuel pump circuit on it and jumper it this will turn it on with the key on.
Wednesday, September 2nd, 2009 AT 7:56 PM
SWANY1967
What would I put the jumper on to make sure the pump is on with key on?
Monday, September 7th, 2009 AT 10:59 AM
