1994 Chevy Truck antifreeze leak
941500K
  • 1994 CHEVROLET TRUCK
Engine Cooling problem
1994 Chevy Truck V8 Four Wheel Drive Automatic 195k miles
I have an atifreeze leak and cannot find the leak, I have check heater core, radiator, and all hoses and all are ok, the leak is coming down drivers side, down the very back of engine, heat in vehicle is doing fine
Tuesday, January 27th, 2009 AT 10:44 AM
BILLYMAC
  • 2,204 POSTS
Hithis could be a cpl things. Intake gasket. Heater core hoses. Freeze plug. You need a pressure tester. Most auto parts stores have a tool rental program. But not real expensive anyway. This tool pressurizes the cooling system and makes it easier to see exactly where it is leaking. Good luck billymac
Tuesday, January 27th, 2009 AT 10:51 AM
941500K
Thanks, ill check this out
Tuesday, January 27th, 2009 AT 11:19 AM
