1994 Chevy Truck
ENGINE43
  • 1994 CHEVROLET TRUCK
Electrical problem
1994 Chevy Truck V8 Four Wheel Drive Automatic
my engine starts up fine but when I put the transmission in gear the motor dies.
thanks for help.
Tuesday, December 23rd, 2008 AT 9:27 PM
  • 109,867 POSTS
Hi:
First, is the check engine light on? You may want to scan the computer scanned for trouble codes. It may be a sensor causing the problem. Also, check for vacuum leaks. Listen for hissing sounds from the engine area.
Friday, December 26th, 2008 AT 12:12 AM
ENGINE43
The check engine light is not on and there are no computer codes and no vacumm leaks. Now what?
Sunday, December 28th, 2008 AT 7:57 PM
  • 109,867 POSTS
When you put it in gear, does it immediatly die or does it spudder and can you keep it running?
Monday, December 29th, 2008 AT 12:49 AM
