89 chevy 2500 4x4
RIDEDAN2
1989 chevy 2500 4x4 350 motor about 100k automatic trans. When I start the vehicle it will run fine for aprox 15 seconds and shuts off. If i turn the key off as it stalls and quickly turn the key on, the truck will run agian for 15 sec and stall again? It has a throttle body injecton.
Oct 12, 2007 at 3:44 AM
MERLIN2021
  • 17,250 POSTS
What you need to do is figure out what it's not getting, gas or spark, then you can figure out were to look, check em and get back to us!
Oct 12, 2007 at 5:46 AM
RIDEDAN2
[quote:8c4fd1d0dd="merlin2021"]What you need to do is figure out what it's not getting, gas or spark, then you can figure out were to look, check em and get back to us![/quote:8c4fd1d0dd] The truck is running out of fuel, I sprayed ether in throttle bodie when truck stalled and it continued to run on ether until i stoped
Oct 12, 2007 at 8:23 AM
