Im not getting fuel to the motor and the fuel pump, and fuel filter has been changed. I also checked the lines to see if they where pluged. What could it be
Sunday, October 17th, 2010 AT 8:15 PM
MECHANIC
When you turn key to run-do you hear the fuel pump come on? If so check the fuel pressure if its within-if okay
Check if the injectors are pulsing providing fuel to the cylinders.
